Question New TV, no sound to HDMI ARC soundbar, but stops tv speakers
Discussion in 'Soundbars, Soundplates & Soundbases' started by compact, Jul 15, 2018.
  1. compact
    compact
    Aug 1, 2007
    67
    9
    TV: Digihome 49 Inch 49298
    Soundbar: Hitachi 240w 2.1ch sound bar with wireless subwoofer
    Extras: Nvidia Shield TV
    Soundbar is connected to TV via HDMI (ARC to ARC)
    Shield connected to TV via HDMI
    I have tried different settings on TV and Soundbar (limited settings).
    Select HDMI Arc on the Soundbar remote, the sounds disappears from the TV speakers, but no sound from the Soundbar.
    The soundbar remote displays icons on the TV for Mute, Sound Up, Sound Down etc
    Select Optical on the Soundbar remote, the sound is back on the TV Speakers, but no sound form the Soundbar, no icons displayed when pressing the soundbar remote.
    TV/Settings/Other Settings/more: Speakers TV, or Amplified (neither make this work)
    Any ideas?
  2. JayCee
    JayCee
    Jan 20, 2004
    24,004
    Lanarkshire
    +2,618
    Have you checked the sound settings on the shield?
  3. compact
    compact
    Aug 1, 2007
    67
    9
    Hi, there aren't any sound settings on the shield that i can see.
    Also it's doing the above, no sound when on normal Digital TV
  4. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,933
    The Borders
    +3,575
    ARC and its buddy CEC can be a bit of a lottery - the best 'fix' is often to disable CEC, which in turn disables ARC, and revet to an Optical cable between the TV Digital Out and the Soundbar Digital Input (I am assuming they both support Optical Digital audio).
    Joe
  5. compact
    compact
    Aug 1, 2007
    67
    9
    HI @Joe Fernand yeah I'm going to pick up an Optical Cable. Shame looks like I didn't win the lottery this time:(
  6. turk3y
    turk3y
    Dec 17, 2005
    3,253
    +1,035
    If you go to your sound menu do you have digital out? If so can you set it to LPCM , wav or anything other than Dolby or Ac3?
    It could be the TV is sending an audio codec or container the soundbar does not support.
  7. compact
    compact
    Aug 1, 2007
    67
    9
    Hi @turk3y That worked.
    Cheers.
    The Bar doesn't turn on with the TV, but it's a start
