Question New TV, Need Advice with Mount
Discussion in 'Home Cinema Buying & Building' started by Droogan Leader, Jun 24, 2015.
  1. Droogan Leader
    Droogan Leader
    Jun 24, 2015
    2
    4
    USA
    Hi Everyone!
    I recently moved into a new apartment building and received a 65" SONY X850C as a wedding gift My wife and I are wanting to mount the TV on the wall over a credenza. I busted out some of my tools, and ran the stud finder over the wall and found that I have studs 24" apart, made from metal.
    The caveat is that the stud is smack dab in the center of the wall :/ The low-profile mount I bought won't reach across to the studs to the right or left. The TV weighs in at 79 lbs., could I slightly offset the mount, drill toggles into the stud and toggles into the drywall? Cutting out a big chunk of the drywall is not an option.
    I've attached a little diagram of what I'm looking at here:
    http://i.imgur.com/vbcwVXH.jpg
    Do I need to go get get a beefier mount? This is what I got off Amazon:
    http://www.amazon.com/VideoSecu-Pro...1&sr=8-1-spell&keywords=videosecu+low+prifile
    Thanks for all the help! Much appreciated.
  2. Member 581642
    Member 581642
    Jan 3, 2012
    11,106
    +2,501
    I got a toaster and some cutlery :)
    TVs are a lot lighter than they used to be but you need two fixing points
  3. Droogan Leader
    Droogan Leader
    Jun 24, 2015
    2
    4
    USA
    Haha! Well, the mother-in-law definitely hooked us up!
    If I a get a mount that covers the middle stud and the stud to the right (not outlined in the above picture), will the TV be centered on the wall? I don't think it could slide over on the mount THAT much.
  4. Member 581642
    Member 581642
    Jan 3, 2012
    11,106
    +2,501
    I know the US is litigious so don't quote me but yes.
