New TV - faults or not?
Discussion in 'TVs' started by Dan666, Nov 13, 2003.
  1. Dan666
    Dan666
    Jul 4, 2002
    144
    OK, if anyone can confirm these as 'characteristics' or actual faults Id be very grateful. Can any of them be easily fixed with the service menu?
    The TV is a Toshiba 32Z23.
    • Left half of the screen has a slight slope - picture on this side seems to bend towards the bottom of the screen
    • When viewing digital TV channels, areas of bright colour can sometimes appear to flicker very slightly. Also, they can appear a bit blurry with surrounding colours (most eveident with the BBC channel idents between programs)
    • When viewing DVDs, the middle of the picture seems to be much darker than the top and bottom (particluarly evident on fade-to-wide transitions)
    I had none of these issues on my previous Philips 24" WS TV, using the same source hardware.
    Thanks in advance.
