Hi there.
Apologize if this is in the wrong place... Please move if need to...
Here's my new issue. I have a new - 4 month old Sony KD75X85J TV that I paired with my previous Onkyo TX-nr 709 receiver. When I first got the new TV, everything paired up perfectly. No issues what so ever. Last week an update for the new TV came out and I updated the firmware.
Since then, when I turn everything on, I get a white (all spectrum colours I guess) pixelated screen at least half the time. Sometimes it starts up as normal but there's no rhyme or reason as to when or what will happen. Just occurs on start up.
I've had Sony tech connect in and the settings are fine. I've never experienced this with previous TVs or this TV until the firmware update.
So i'm at a standstill and don't know what to do. The "workaround" is when I turn on the system if I get the white screen, I turn everything off and the start again. I do this until I actually get a picture. It may happen the next time I turn everything on or it may happen after 2 or 3 tries.
I've tried different HDMI inputs in the TV with no luck. I've tried different pass-through options with no luck. Tried different cable no luck.
I do see when I turn it on that the notification for the current HDMI input on the TV will pop up a few different times.
I am using a Harmony remote to power everything. I've tried it with the TV and receiver remotes and same issue. I've tried delaying start up of either the TV or the receiver as well but that hasn't made any different. I've turned either the TV on or the receiver on then waited 5-10 seconds to turn the other on without any success.
Kind of at wits end on what to do. Sony says previous firmware cannot be reinstalled. This issue completely started with the firmware update. The way it is, it's just not going to work for my family. They're not going to keep turning off and then on etc... I don't understand how it was perfect before the update and now it's not.
The issue appears to be the communication between the receiver and the TV. Is there any other way to hook things up if I want sound from my receiver and audio system? I am using a Cogeco TiVo box.
Everything goes through the receiver and then the receiver to the TV. The receiver has the inputs and ability to switch them depending on what I want to do. But the signal is obviously now not getting to the TV properly or the TV cannot manage it. I will say, even with the white screen the sound is perfect and there is no issue with that part. Only the video...
Any help is greatly appreciated!
Thank you!
Thank you!
