Question New Turntable Advice
El Bayno
I have recently returned Project Classic (with Ortofan Quintet Red MC) as the SoundBox on it developed a fault (played at 38rpm!).
It has damaged my confidence in the model/brand and I am looking to spend my refund money on a replacement. In total I will have a budget of £1000-£1500.
The turntable was a recent upgrade from Project Debut 3. I loved the extra detail I could hear on the classic/quintet though… if I was picky I found it lacked a bit of bass and warmth for my uneducated ears.
I would like to buy something that would be comparable to the classic which will also stretch the other components I have…as I aim to replace those later down the line as my budget allows. The other components I have are….
Project Phono Box USB V Pre Amp
Roksan Kandy Amp MK 3
B&W CDM1 NT SE Speakers
I listen to all types of music but lean towards acoustic/jazz.
Happy to receive all suggestions and to be given direction on the candidates I should consider.
Thanks in advance.
DT79
Clearaudio Concept
El Bayno
Thanks. Yes have had a look at that. I also looked at rega planar 6. My concern with the rega is if I go for MC cartridge I may need to buy a Rega Phono Stage. Does anyone know how the Rega may sound with my existing Project?
Ugg10
The Marantz TT15S1 is also worth a look, designed by Clearaudio, nice tone arm and comes with a very good Virtuoso mm cartridge. The cartridge can also take the AT VM95 stylus range with a bit of surgery to the plastic on them, ML or SH versions are a good upgrade.
BT Bob
I don't know that preamp, but I can vouch for the P6 - for me, it's the sweet spot in the Rega range.
if you're concerned about the MC performance of the Project, look at the P6/Exact combination. I have the Ania, but the Exact gets great reports om the P6.
DT79
No your current phono stage supports both MM and MC cartridges.
I don‘t know how it compares to Rega’s offerings, but you don’t need a Rega phono stage. Certainly a phono stage upgrade isn’t something you necessarily need to consider yet.
daddy999
I’d go with the Rega Planar 3 / Ely’s 2. For the money, I’ve not heard better and boy did I try a lot of turntables, some way more expensive.
Samsung Micro LED, Mini LED, NEO QLED TVs and More: AVForums Podcast Interview
