New tuner ?
Discussion in 'Arcam Owners' Forum' started by onvt, Feb 15, 2005.
  1. onvt
    onvt
    It seems that the tuner part of the new Arcam solo is based on a new model from Arcam... Anyone has more info on this new tuner?
  2. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,523
    Edinburgh
    +1,243
    DiVA DT91 DAB / FM tuner Introduction
    • combined DAB & FM-RDS radio tuner
    • attractive easy-to-read graphics display
    • all digital processing for FM
    • DAB coverage for both band III and L-band
    • 16 presets, randomly assignable to DAB or FM
    • audiophile design using 24-bit Wolfson DACs
    • full remote control via RS232 or IR
    • digital output from DAB or FM
    DiVA range gets new combined DAB / FM tuner
    As the first company in the world to produce a domestic Digital Radio tuner, Arcam has played a pioneering role in the rollout of DAB digital radio. The Alpha 10 DAB tuner and subsequent FMJ DT26 and DiVA DT81 digital radio receivers, all engineered and produced in the UK, have gained a reputation as some of the best in the world.
    The new DT91 builds on this foundation, using state-of-the-art technologies to deliver the very best radio quality from DAB and FM broadcasts. All-digital processing using a powerful DSP delivers crystal clear reception regardless of the broadcast method. The digital to analogue conversion and output stage designs use Arcam’s audiophile methodology and are fed from a toroidal power transformer and multiple low noise regulated dc power supplies, all mounted on a double-sided fibreglass PCB. Station selection is via presets or the large front panel knob. The 128x18 VFD display has smooth scrolling text and is easily read from any angle or in any light condition.
    In addition to its class-leading audio performance, the DT91’s connectivity and control features are also state of the art. The RS232 control input, a first for domestic DAB radios, makes the DT91 a perfect radio tuner for custom installations using Crestron or AMX style system controls. For simpler systems the unit features an IR jack input on the rear panel plus a fully featured remote handset. Outputs include two pairs of analogue RCA phono sockets plus coaxial and optical digital outputs for both DAB and FM.
    Delivery of the DT91 is due February 2005.
    UK recommended retail price (inc VAT) £449.90
  3. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,523
    Edinburgh
    +1,243
    DiVA DT91 DAB / FM tuner - Technical specifications
    DAB digital radio
    • Tuning range from 174 – 240 MHz (band III) and 1452 – 1492 MHz (L band)
    • Sensitivity – better than –91dBm, typically –97dBm
    • Maximum input level – 0dBm
    • Maximum audio data rate 256kbits/sec at MPEG protection level 3
    • Aerial connection – F type 50 ohms, also used for FM
    FM radio
    • Tuning range from 87.5 – 108 MHz (band II) in 50kHz steps
    • Sensitivity (IHF) typically 3 microvolts
    • Signal to noise ratio 65 dB at full modulation ref 1kHz
    • Distortion 0.1% at full modulation ref 1kHz
    • Frequency response 20Hz – 14kHz +/- 1dB
    • Stereo and mono outputs available (selected via menu)
    • De-emphasis - 50 microseconds standard (75 microseconds option for Canada)
    Analogue audio performance
    • Audio DACs – Wolfson WM8740 (24bit 192kHz) used in differential mode
    • Analogue output levels at full modulation – DAB 2.4V rms, FM 0.9V rms
    • Frequency response 20Hz – 20kHz +/- 0.5dB
    • Output impedance less than 100 ohms
    • Minimum recommended load impedance 600 ohms
    • Two pairs of paralled outputs using gold plated RCA phono sockets
    Digital audio outputs
    • SPDIF co-axial (gold plated phono socket) and optical (TOSLINK)
    • Sampling frequencies – 48kHz (DAB) and 32 kHz (FM)
    Display and user interface
    • Top quality Itron vacuum fluorescent graphics display – 128 x 18 pixels – much better than LCD
    • Supports 2 lines of 21 or more variable-width characters, including smooth scrolling text
    • Display can be turned off or dimmed via the remote control handset
    • Shows station name, plus programme type (PTY), 128 character scrolling text (DLS) and audio data rate on DAB. Shows station name, programme name and scrolling radio text on FM
    • 16 presets, randomly assignable to DAB or FM, for favourite stations
    • Large smooth tuning knob selects individual DAB stations from an alphabetical list stored in the DT91’s memory, or via station frequency for FM
    Custom install features
    • Full duplex RS-232 control interface via 9 pin D-type connector; also suitable for system software updates
    • 36 kHz modulated RC-5 input on 3.5mm mono jack
    • Full suite of discrete IR RC-5 codes available, including separate on / off commands
    General
    • Supplied CR389D IR remote control includes basic support for Arcam amplifiers and CD players
    • Supply voltage 230/115V, 50 - 60Hz, set by selector switch on rear panel
    • Power consumption <20VA
    • Size – 430mm wide x 320mm deep x 85mm high
  4. Hede
    Hede
    Aug 17, 2004
    2
    4
    Any news on a new FMJ dab/fm tuner?
  5. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,523
    Edinburgh
    +1,243
    Nope none.
