new toshiba in currys 42wh38b
Discussion in 'General TV Discussions Forum' started by jumbopants, Oct 8, 2003.
  1. jumbopants
    jumbopants
    Jul 31, 2003
    uk
    +4
    Went down the local currys today, and they had the new Toshiba 42wh38b, does any one know if you can buy this set on-line at a cheaper price than 1299.99 than currys are doing it for ?? It look the same as 42pw33 but has dolby digital surround sound 5.1, I have done a search in google but could not find any specs. ?? Does this set have progressive scan aswell ?? See the image I scanned in for info.
  2. nathan_silly
    nathan_silly
    You can buy the 51" version for £1355. ;-) Haven't seen prices for the 42", however somewhere probably £1000-£1100
    Check www.unbeatable.co.uk
    The new sets are Stereo only (good) as they sound rubbish anyway..go down the seperates route.:smashin:
  3. jumbopants
    jumbopants
    Jul 31, 2003
    uk
    +4
    This set has 5.1 digital built in ! Have a look at the spec on the right had side of the tv, plus it says on the set aswell when I saw it in the shop, can't find this set anywhere alse - not even currys online ??
  4. nathan_silly
    nathan_silly
  5. jumbopants
    jumbopants
    Jul 31, 2003
    uk
    +4
    not sure about the inputs as I can's find any specs. on this set ? Think it must be exclusive to currys...
  6. Loada
    Loada
    Mar 4, 2003
    591
    Guisborough, North Yorkshire
    +51
  7. nickj24
    nickj24
    Oct 7, 2003
    153
    16
    all toshiba's tvs hav component inputs & all outputs on dvd players as tosh belive this is the proffesional way to view these.they were the 1st to do so.regards nickj24.
  8. NinjaKi11a
    NinjaKi11a
    Sep 7, 2003
    314
    16
    Thought I'd mention that I got my Tosh 36ZD26P fpr £600 cheaper than the Curry's price. Their price match policy is an empty garuntee as well so I'd ignore the 'if find it cheaper after you've bought it...' line.
