new tosh 220e;speakers now hum!!
Discussion in 'Blu-ray & DVD Players & Recorders' started by wattman, May 31, 2002.
  1. wattman
    wattman
    I have just bought the new toshiba dvd SD-220E. Since cableing it up, i now get a humming noise thru my speakers(centre seems to buzz as well).The amp is only set at -50db.It is connected to my sony 1070 amp by optical cable & to my tv by scart.The only way to get rid of the humming is to disconnect the scart lead. I have looked thru search for this prob but nothing suitable(i think??)
    yours hopefully del.:eek:
