New to Prog Scan - Best Feed for HS10
Discussion in 'Projectors, Screens & Video Processors' started by Turl, Jan 21, 2003.
  1. Turl
    Turl
    I'll apologise in advance as this must have been asked so many times.
    I want to create the best possible source to feed my HS10 and from what I understand this has to be PAL progressive scan. I'm preparing to take the leap into HTPC but before I do can someone tell me if the HTPC route is going to be considerably better than a progressive scan DVD player?.
    Is it to be Radeon 9700 Pro or Denon 2800MkII?
    If it's the DVD route whats the best sub £1,000 player?. I've looked at the Toshiba SD900, Denon 2800MkII, Arcam DV88+ and Phillips 963A (much cheaper I know).
    Aside from the forum, are there any websites you can direct me to in order to improve my understanding of progressive scan video, etc.
    Cheers,
    Turl :)
  2. Iassh
    Iassh
    May 9, 2002
    33
    Valencia (Spain)
    You can take a look to .... www.hometheaterhifi.com
    Also, I have a Primare v25 (PAL & NTSC prog. scan) and the pictures, using a Sony HS1, are great.
    Bye.
  3. Turl
    Turl
    Iassh,
    Many thanks for the link. Anyone pondering over the HTPC / Standalone player route should visit this site........the results from the sites progressive scan shootout are very surprising indeed.
    Cheers,
    Turl
