Hi all, Firstly I just wanted to say what a great bunch you are and thanks to all of you that have posted your plasma pics,
Anyway, I am thinking about replacing my 42" rear projection set with a plasma and I want some advice from people not on commission.
I want to use the TV for everyday use amd in my house it is normally on all day and evening, will this casue a problem?
Is the PQ normally OK from SKY?
Does the angle of viewing make a great difference? I will have to join the above fire place group, which means one sofa is directly in front but the other is a way of to the side, does that effect the viewing?
I remember all the older stories about plasma's not lasting long if used for everyday TV, is this true or just gossip?
Also, I cant warrant spending silly money on a TV, and I notice that richersounds have a relisys in for £2K, has anyone had any experience with these or I am better saving my 2K and getting a projector to compliment my 42"rear projector setup?????
Thanks in advance
Dave
Thanks in advance
Dave
