jamclear276
I've had KRK Rockit 6s for some time, and wanting better sound quality I did a bit of googling and learned about lossless audio. Most of it still goes far over my head, but after some googling I found that I'd be able to do a pretty rudimentary setup with items I already owned. I suppose I should describe the setup before I get into the issues which have arisen:
First, I set my Macbook Pro's Built-in Output to 2ch 24-bit Integer 96.0 kHz, and downloaded ALAC tracks which I play in Vox; I ran a digital optical cable from the Macbook's 3.5 mm headphone output to a Digitial to Analog Audio Converter; the DAC output had both RCA and 3.5 mm headphone, and the only cable I had was a 3.5 mm to RCA chord, which I plugged into an American Audio M822FX mixing console that controls the KRKs/headphone output.
Now I'm sure someone with knowledge of lossless audio will (hopefully) be able to spot any glaring issues with what I have described. I have successfully played these tracks over the KRKs with no major sound problems; I just don't really have a way of knowing if any data loss is occurring anywhere in the system. I tried listening to a few tracks using a pair of Sony MDRXB950N1 headphones connect to the mixing console by the 3.5 mm cord that came with the headphones and a quarter inch male adapter; the volume was very quiet, and when I tried various combinations of levels across the different volume controls (Vox volume control, the channel volume on the M822FX, the control room volume for the headphones, and the master volume) I found that when the track became comfortably audible I noticed some pops and cracks, and with the volume turned even higher I noticed consistent rattling on bass kicks or similar impactful sounds. I'm sure that the headphones are not blown, as I tested them on my iPhone on a louder volume, but using a standard mp3 track, without any noise distortion.
To summarize, I suppose my concern: is there a point in my setup where I am losing data that could be causing the unpleasant playback in my headphones, as I would like to avoid these pops and cracks during playback on my KRKs.
like the title says, this is all new to me, so I hope my descriptions/terminology is adequate
