New to dvd recorders - please help
Discussion in 'Blu-ray & DVD Players & Recorders' started by c18udy, Dec 16, 2004.
  1. c18udy
    c18udy
    Hi all,
    Thinking about getting a dvd recorder for xmas but had a few questions before i spend all my dosh
    Looking to spend no more than approx £170 so first question is any sugestions?
    I have seen a few on dixons - are they any good?
    http://www.dixons.co.uk/martprd/sto...sku=007681&category_oid=-21898&fm=5&sm=1&tm=1
    http://www.dixons.co.uk/martprd/sto...sku=818193&category_oid=-21898&fm=5&sm=1&tm=1
    Also i have a TV/VCR combined tele - would i be able to recored from video to dvd easily ?
    Does this included rented videos?
    really apreciate any help you can give
  2. clawson
    clawson
    As on DS - Pioneer 220 or Pana E55 for around £170.
    Cliff
    (and those links STILL don't work!)
  3. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    I'll second that - and if your TV can output VHS to the scart socket, you should be able to transfer tapes, but you'll need one of these to record commercial VHS tapes to DVD.
  4. c18udy
    c18udy
  5. bboy-mass
    bboy-mass
    Dec 31, 2002
    322
    Birmingham
    +12
    Just purchased the ASDA 4-Cus recorder (same as the Liton - but not as nice to look at), and Im well impressed for £130 notes. The DV-I link was bad through, but that might be down to my camcorder. Switching to Anaolg was better, and recording from cable in HW mode is great for me.
    Regards
    Mass
  6. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    The Liteon isn't bad, but the Matsui is an "own brand" which I wouldn't go near ! Liteon make drives which are rebadged for many manufacturers. However, if it were me, I'd save up a bit longer and get a Pannie E55 :thumbsup: :)
  7. c18udy
    c18udy
    im still a bit confused about what can be recorded and what cant and a few other simple questions
    Can i record rented videos (i have a tv/vcr combo tele)
    can i record from sky
    can i record bought videos
    how much can i fit on a normal recordable dvd
    does a recordable work the same as a video - record over it and the stuff on there stays on (if the first programme was longer)
    if i have a playstation can i record dvds from that ?
    Thanks again
  8. dmjohnson123
    dmjohnson123
    Nov 25, 2002
    265
    Wetherby near Leeds
    +5
    Can i record rented videos (i have a tv/vcr combo tele)?
    If your combo sends out a signal from an external connection then in principle yes you could (see instructions for your combo unit). As someone has mentioned before most commercial videos (inc rented) have copy protection encoded which will stop the DVD recorder recording unless you use a 3rd party device connected inbetween the combo and the DVD recorder.
    can i record from sky ?
    Yes
    can i record bought videos ?Same answer as for rented videos
    how much can i fit on a normal recordable dvd ?Depends on the DVD Recorder but typically 2-3 hours in high quality, 4 hours in low quality and upto 6 hours in very low quality
    does a recordable work the same as a video - record over it and the stuff on there stays on (if the first programme was longer) ?
    Not Really. You can use write once discs which are ideal for recordings you wish to keep or give away to friends. Or you can use re-write discs which are more like videos in that you can record something tonight, watch it, then delete it off the disc and re-record something on the same disc tomorrow night. If youve got 2 recordings on 1 disc you can delete 1 and re-use that space on the disc whilst still keeping the other recording intact on the disc.
    Not sure on this one
    Finally, if your looking for a DVD recorder to be used as a replacement for video you won't be disappointed - the picture quality, even on 4 hour recording quality is as good as any VHS recorder i've seen and on 2 hour recording quality its perfect - no lines, skips or sound quality blips as per VHS.
  9. c18udy
    c18udy
    thanks so much for those answers - starting to get a clearer picture now
    Whats the main difference between say the LITEON LVW5001B £130 in dixons and say a players for £250+
  10. clawson
    clawson
    The more you pay the more likely it is that the thing will actually work!
    Japanese quality brands (Sony, Panasonic, Pinoeer, JVC, Yamaha) have huge R&D teams and multi-million-$ development budgets making sure that what you buy has been thoroughly tested before it ever hits of the shores of Europe.
    No name Chinese/Taiwanese brands (Liteon, Relisys, Targa, Technosonic) have a budget of three sticky toffees that have got hairy in the bottom of someones pocket and a guy called Fung with a sledgehammer who sits out back and hits each unit as it comes off the production line. If nothing drops off they put it in a box and sell it. You get to become a pioneer technician and do their alpha/beta testing for them. If you find something seriously wrong then, if you're lucky, they post a firware update on their website to fix the problem 18 months later and you have to go through some tortuous procedure to get it into the box. This does not happen if you buy a Sony. (or Pioneer or Panasonic etc.)
    The luxury of having something that's been tested generally costs about £30-40 more on a product in the £100-£200 price category.
    It's your choice - some people have bought the cheap brands and hit lucky (i.e. they don't need to do any of the things on it that maybe don't quite work just yet!).
    As the saying goes "You pays your money and you takes your choice"
    Cliff "the cynic"
    PS Somewhere in the middle between Japan and China sits the Netherlands (no, really!) and located there is a company called Philips ;-)
  11. waz2004
    waz2004
    Sep 14, 2004
    295
    +6
    on panasonic e55 how long can i record onto a bog standard disc? not refering to ram.
  12. clawson
    clawson
    ON a DVD-R the E55 can do:
    XP - 1 hour
    SP - 2 hours
    LP - 4 hours
    EP - 8 hours
    Cliff
  13. stevelup
    stevelup
    Aug 13, 2002
    6,142
    Swindon
    +855
    Hi, Can you tell me where to find those machines for those prices please?
    Many thanks,
    Steve
  14. clawson
    clawson
    Richer Sounds have the Pioneer 220 for £169.99:
    http://ws4.richersounds.com/product...ch=pioneer&feature=DVDRECORDERS&manufacturer=
    (in the discontinued/last few section at the bottom of the page but most stores are listed as still having 2 or 3)
    Personally I ordered the Panasonic E55 from Currys.co.uk for £189 but they had a 10% off code that then reduced this to £170. Sadly that code has now expired though (last Wednesday) so you may find it tricky to get this price.
    Cliff
