New to DVD cannot burn from studio9???
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by blue2555, Jun 25, 2004.
  1. blue2555
    blue2555
    Please would someone help me on this issue.
    I have a X64 3000+mhz pc with 512 ram and 200 gig HD, with *8/4 -/+ dvd writer.
    running Windows XP home edition.
    I am completely new to burning DVD.
    I am trying to burn from Studio 9 to a DVD+Rw disk using a short sequence of 5 mins. When I choose to make a disk to dvd using studio 9, the process always stops at about 80% of the process. The PC just sits there for ages!.
    I have burned short test sequnces to DVD using Sonic DVD with no problems.
    1)I would like to know the correct way to burn DVD's from scratch, should I let Windows XP burn the format & DLA the disk or find another programme? or i is there something else I should be doing?
    2) I would like to use Studio 9 for the whole editing process to DVD, or should I just be using it to edit and convert the final cut to MPEG and use a different application to burn to DVD?
    I also have Premeire 6.5.
    I would also appreciate to know basics of formating and setting up dvd etc.
    Many thanks for any feed back.
  2. dedman
    dedman
    Dec 11, 2002
    45
    Reading, UK
    +12
    Hi blue2225,
    Am in a similar situation to you as I have recently began to get into videoediting and DVD authoring. Found this site www.videohelp.com which has loads of useful information on - check out the menus on the left. They don't seem to rate Pinnacle Studio very highly, going more for TMPEGenc DVD author and Ulead MediaStudio or Video Studio.
    Good Luck
  3. blue2555
    blue2555
    Thanks for your help. I will take a look.
  4. Orbitalzone
    Orbitalzone
    Feb 23, 2002
    394
    E.Sussex
    +43
    Have you upgraded Studio9 to the latest version? (use the update feature to check)
    The latest patch can solve many problems.
  5. blue2555
    blue2555
    thank you for that. I will download and try out.
  6. Blu Ray
    Blu Ray
    Jun 14, 2004
    495
    Chorley, Lancs
    +12
    I had this problem until I stopped 'InCD'. For some reason, Studio didnt like it running in the background.
  7. whiteswan
    whiteswan
    Dec 9, 2002
    867
    Oldham
    +38
    Studio doesnt like anything running in the background.
    Do a Google for a free program called end it all - this shuts down all background tasks with 1 click.
    Dave
    PS This is in the Studio 9 help file but its buried!
  8. Dennis Leighton
    Dennis Leighton
    Apr 19, 2003
    381
    28
    Priorslee,Telford, Shropshire
    +59
    Sorry to be a 'killjoy' but End it All is no longer a 'freebie' - apparently stopped for legal reasons. Shame!!
