New to DV... a couple of questions
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by Orbitalzone, Apr 20, 2003.
  1. Orbitalzone
    Orbitalzone
    Feb 23, 2002
    394
    E.Sussex
    +43
    Hi Everybody!
    I'm looking to get into DV editing on my PC, but it's old... a PIII 800Mhz with 256 ram...
    Will a basic firewire card and software (I'm thinking of around £100 for card/software) do for a DV novice and how long would my spec PC take to actually render the finished edit, say a 25 minute home movie?
    I'm planning to burn straight to DVDr within the PC...
    any help welcome!
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,353
    Rainham Essex
    +2,441
    Your PC will work fine for DV editing, but you must be running Windows98SE or later. DV cards do NOT work on Win98 or earlier.
    To start with you could get a basic firewire card & software for around £30 and update the software later if the bug bites.
    Rendering times will also improve drastically if you were to upgrade just the memory on your PC. A 256Mb DIMM will only cost around £20. Check what your motherboard can take, but on a PIII m/b you should have no problems. There are too many variables to give exact rendering times, but should be no more than overnight :eek: . This sounds a lot but is what I do when rendering footage on a PIV with 512Mb RAM.
    Also remember you will need LOTS of disk space, and a separate disk for footage is recommended. 4 minutes of footage captured at full quality will take 1Gb of disk space, and you will need more spaced to edit/render etc.
    Mark.
  3. Orbitalzone
    Orbitalzone
    Feb 23, 2002
    394
    E.Sussex
    +43
    Thanks for the reply!
    Now where's my wallet?
