New To BiWire
Discussion in 'Cables & Switches' started by TimHiFi, Feb 2, 2005.
  1. TimHiFi
    TimHiFi
    Feb 2, 2005
    84
    Reading
    I'm thinking of biwiring my front three speakers.
    Am I right in assuming that each biwire cable should have two connectors at the Amp end, and four connectors at the speaker end ?
    I have seen some set ups that have two connectors at the Amp, but just open ends at the other.
    Is this just a matter of choice, or cost ?
  2. Reiner
    Reiner
    Jul 16, 2000
    3,315
    61
    Germany
    +13
    Yes, you could say that.
    You probably mean the A and B terminals at the amp. They were not intended for bi-wiring but rather for a 2nd pair of speakers (typically located in another room).
    However you can of course use them to bi-wire - that way you don't have to squezze two wires into one connection (see above).
