New Terminal Board?
Discussion in 'Plasma TVs Forum' started by moid, Mar 13, 2005.
  1. moid
    moid
    May 9, 2003
    40
    Leeds - UK
    I have a pwd6 with the following setup:
    Slot 1 - Scart terminal - AV source Selector (2 scart inputs) - Xbox & Sky
    Slot 2 - Component terminal - DVD player
    Slot 3 - Empty
    But I also have my pc (s-video) which needs to be connected.
    I currently do this by unplugging the av source selector from Slot 1 and using a s-video to scart connector as the pc will only find the plasma if I connect to it directly (i.e. not through the AV source selector)
    This is beginning to annoy me and cannot be good for the Terminal board in the long term. :(
    So... do I:
    (a) - spend £130 on a Scart terminal board, and move the component terminal to Slot 3 (Scart only working on Slot 1&2)
    (b) - spend £130 on a terminal board with an s-video connector on
    (c) - something else (less expensive if possible)
    By the way - I cannot use the PC slots on the back of the plasma as the hole through the wall connecting the PC to Plamsa is too small (and increasing it to fit a DVI connector isn't an option!)
    Sound wise - no issues - all goes through the AMP.
    Any ideas? Cheers.
  2. swellmel
    swellmel
    spend £43.75 for scart board from sales@panastore.co.uk
    send them an email,you can also pay over the phone using c/card -price above includes delivery next day
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Or get the dedicated video board with an S-VHS socket...(S-video is crap for PC why not use VGA????
  4. moid
    moid
    May 9, 2003
    40
    Leeds - UK
    Not quite sure what you mean. :confused:
    You got a link or picture to one of these boards?
  5. Rambles
    Rambles
    Jul 14, 2004
    8,318
    UK
    +1,288
    Yeah, why don't you - it will look inifintely better than s-video?
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    S-Video board (BNC)
  7. moid
    moid
    May 9, 2003
    40
    Leeds - UK
    I had thought about it but the VGA cable is only a bit smaller than the DVI - still won't fit through the hole.
    Just another point - if I buy the s-vhs board and move it to slot 2 (only works on 1 and 2) will my component board be ok in slot 3?
  8. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    component will work in slot3 fine if cable ize is an issue could use Mini coax in RGBHV BNC form Vandamme and a couple of others do mini coax!
    MOid would an HDMI cable fit in the whole these are slightly bigger than USB.... and USE DVI to HDMI adapters at both END best option......
  9. moid
    moid
    May 9, 2003
    40
    Leeds - UK
    Money money money!!! :eek:
    Would cost a bomb!
    Think I am going to go for the s-vhs board option - £85 damage
    Cheers for the help though!
  10. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Warning! This will look total crap on picture, sorry to be so blunt. You could make up your own VGA cable, buy the plugs from maplins and use a length of shielded cat5 as the cable. That works OK up to about 5m, after that you need dedicated video over cat5 baluns, they are about £110, will work up to 100m!!!! or so. Then you can use the VGA port, so marginal increase in cost if you use the baluns, massive saving if you can solder to the required standard. Done this 1000's of times, comes with the MAW satisfaction guarantee. cat5 is of course about 8mm thick, and you terminate with 50p plugs and £10 pliers, it's really really easy.
