giggsy1950
Hi everyone, compliments of the season to you.
My parents television is the Samsung LE40B550, bought on the basis of the review on this site many years ago! It's a CCFL back-lit LCD screen and doesn't have local dimming and such, which I kind of like as the black level (which is pretty good for such an old screen with old technology) is consistent. I seem to recall reading a good quality panel was used at the time.
Anyway, it's starting to flicker, the dirty screen appears to be getting worse and it sometimes takes a long time to power up from standby.
I like the thought of FALD to keep the light output consistent across the screen as opposed to edge-lit.
My folks have Sky Q but not HDR. I looked at the Samsung QE50QN94A initially but although they could afford it I suspect it very much overkill for their viewing needs. This then led me to the Sony X90J at 50 inches which is a few hundred pounds less.
I'm thinking 50 inch screen, 55 at a push, but would like to avoid edge-lit as blooming gets on my wick when I go round to watch (and they would likely notice as I have trained them well!).
I also considered OLED, but my father has the news channel on a lot and screen burn could be a possibility.
Any thoughts on what else I should consider before checking out the Sony on store?
Many thanks.
Many thanks.
