New Technomate HD Boxes
Discussion in 'Satellite TV, Sky TV & FreeSat' started by thfccambs, Sep 17, 2007.
  1. thfccambs
    thfccambs
    Jul 17, 2002
    23,968
    White Hart Lane
    +6,898
    [​IMG]
    Prices are from £279 -£299
    TM-6900 HD COMBO
    Specification
    2 High Definition Tuners: DVB-S/DVB-S2 Satellite & DVB-T Terrestrial Compliant (MPEG-II/ MPEG-IV/ H.264)
    Output Resolution: 576p & 576i, 720p & 1080i
    1 Smart Card Reader & 2 Common Interfaces (2CI)
    HDMI & Component Output (YPbPr) with Upscaler to Improve Picture Quality
    10,000 TV & Radio Channels
    USB2.0 PVR Ready via external HDD or USB Flash Drive (memory stick) with Timeshift, Record & Playback functions
    MP3 player and JPEG viewer via external HDD or USB Flash Drive (memory stick)
    Software & Channel List download via USB 2.0
    Fully Featured VFD text Front Panel Display
    Sensitive Tuner
    Less than 1 second channel change
    Dolby Digital Optical S/PDIF
    DiSEqC 1.0, 1.1, 1.2 & 1.3 (USALS) compatible
    Auto Navigation system – select as many satellites as you want to search
    On-screen display with true full color resolution
    Enhanced 16 Favorite channel groups
    Channel control by: Favorites, Lock, Skip, Move & Delete
    Channel sort by: All, Alphabet, Transponder & CAS
    Multilingual OSD Menu: English, Spanish, Portuguese, French, Dutch, German, Italian, Turkish, Arabic, Russian, Persian
    Extended EPG and program reservation on EPG
    Teletext & Subtitle by OSD and VBI
    Last channel memory function
    Factory default channel list
    Various games
    Software & channel list upgrade via RS-232C: PC to STB, STB to PC, STB-STB and USB
    Parental, Installation & Receiver Lock
    Zoom function on Pause & Live channel
    Multipicture display
    Support for multiple language broadcasts
    SCPC & MCPC receivable from C/Ku band satellites LNBs supported: Universal, Single, Single S & C band wideband LNBs
    Multi TV Standards supported: PAL G, I, K, M & NTSC M with 4:3 & 16:9 Screen Formats
    90-250V AC 50/60 Hz
    LNB Short Circuit protection onboard
    2 Scarts, (RGB, CVBS) & S-Video
    TM-6800 HD
    Specification
    DVB-S/DVB-S2 Satellite Compliant (MPEG-II/ MPEG-IV/ H.264)
    Output resolution: 576p & 576i, 720p & 1080i
    Sensitive Tuner
    Various games
    90-250V AC 50/60 Hz
  2. John Henry
    John Henry
    Aug 8, 2006
    935
    New Jersey
    +37
    Are you able to you know what with this box? ;);)
  3. thfccambs
    thfccambs
    Jul 17, 2002
    23,968
    White Hart Lane
    +6,898
    No mate,Linxs boxes you need for that.:mad:
    If dreambox ever pull there finger out that will be the one to buy.:thumbsup:
  4. John Henry
    John Henry
    Aug 8, 2006
    935
    New Jersey
    +37
    Linux box it isn't but the other ;) it can do.
  5. thfccambs
    thfccambs
    Jul 17, 2002
    23,968
    White Hart Lane
    +6,898
    Well if your on about CS from what i've read it won't.
  6. rcaudwell
    rcaudwell
    Feb 22, 2006
    1,360
    63
    Southport
    +156
    There may well be a work around for CS on these boxes, involving having the box connected to a pc at all times, the same as you can do on the technomate 1500, but it`s not a good solution.
    IF I was into CS, I would wait for a HD version of the 9100, or the new (?mythical) HD dreambox.
  7. Orbitalsat LTD
    Orbitalsat LTD
    weve got the the HD TM-6900 instock now waiting for new stocks to arrive. Ive set the TM-6900 up and been using it since Monday, it took me 15 mins from opening the box patchig it and installing it..so simple! basically its TM-1500 software in a HD box and I must say HD is superb on this box. I even copied my channel list from the 1500 to the 6900. You can patch and add a channel list using a USB pen drive and it takes a few seconds. it is PVR ready but you have to connect an external USB hard drive to it.
    Regards
    Orbitalsat
  8. thfccambs
    thfccambs
    Jul 17, 2002
    23,968
    White Hart Lane
    +6,898
    Dave
    if you want a independent person to try this box out mate im happy to do so.
    Can you tell me if this clears skyhd channels or just BBCHD on 28east?
    If you don't know then thats an ideal situation to send me one so i can check for you.:thumbsup:
  9. Orbitalsat LTD
    Orbitalsat LTD
    you can BBC HD channel no problem as far as sly HD channels nope, you can use your sly card with a Dragon\T-Rex in the 6000 series, I dont subscribe to sly HD so I havent tried. I've watched the Premiere HD channels watched the footy the other night superb mate! One other thing you cant get 4:2:2 feeds either.
    Orbitalsat
  10. thfccambs
    thfccambs
    Jul 17, 2002
    23,968
    White Hart Lane
    +6,898
    If you are able to find out about skyhd channel please let us know,also is it true that the input for Hard Drive is at the front of the box?:nono:
  11. kwan.b
    kwan.b
    Mar 26, 2006
    13
    Would any external USB Hard Drive, like say the 250gig Lacie that I have, work with this?
    Also, do I understand it right that this would be compatible with the TM1500 patches?
    Many thanks in advance.
    :hiya:
  12. Free To Air
    Free To Air
    Mar 22, 2004
    1,266
    48
    +48
    Orbital,
    Is that definite that you cannot get the 4.2.2 feeds?
    Also, what is meant by "sensitive tuner", ie, how low a threshold will it go to and produce a picture?
    rgds
  13. satsid
    satsid
    Oct 19, 2006
    62
    +8
    Is there a blind scan on this receiver?or will it take a life time for a blind scan to finnish?just like the tm 1500?Going into the Hd world i feel a receiver should do 4.2.2. today @ least anyway.I know the vantage has a more sensitive tuner than the tm 1500;) when it comes to feeds iv been @ this a very long time.It will be intresting to know what the new tm Hd can realy do.
    sid
  14. tigertimtim
    tigertimtim
    Mar 31, 2005
    1,140
    116
    +719
    no blindscan on it but the tuner is good to be honest, yes theese hd recievers should have 4.2.2 but apparently not even the lygnbox is going to do this.
  15. wellop
    wellop
    I thought I'd give my 2pence:
    I got the TM-6900 COMBO the other day and must say it's a fantastic piece of kit. The menu is like my TM-1000D+ Super so it is very easy to use. BBC HD and Premiere HD works amazingly too. The picture quality certainly blew me away!
    Freeview looks a tonne better than the one built-in to my plasma.
    The 'special' software works like a charm (wink).
    It can't do 4:2:2 or Blind Search, but no HD receiver out now can do them so I'm not disappointed.
    I've found the tuner to be better than my TM-1000D+ Super as it's holding onto the weaker birds a lot better.
    I'm using a 160GB Freecom HDD as it does not require any power.
    All the best,
    wellop
  16. remlap
    remlap
    Apr 8, 2006
    791
    28
    +65
    Still its a total rip off.
  17. thfccambs
    thfccambs
    Jul 17, 2002
    23,968
    White Hart Lane
    +6,898
    Seems the same as the clarke hd5000 which is £80 cheaper.:eek:
  18. wellop
    wellop
    If you shop around, you can get a good deal.
    I've seen people selling the Topfield HD for £250 and that doesn't have half of what the TM-6900 COMBO has so I'm pleased.
    I was looking at the HD5000 but I was told by email from a dealer in Germany who sells both that the TM-6900 COMBO is better as it has better hardware, so I went for that.
    Wellop
  19. thfccambs
    thfccambs
    Jul 17, 2002
    23,968
    White Hart Lane
    +6,898
    From reading on alsat there both the same,i personally would touch the TM HD as it looks pig ugly.:eek: The clarke does the same and is 100 times better looking,and cheaper.:thumbsup:
    Im waithing for the Dreambox but might have a long wait.:rolleyes:
  20. remlap
    remlap
    Apr 8, 2006
    791
    28
    +65
    Combo idea is useless to me, no terrestrial around here and even I did any new tv has DVB-T tuner built in anyway and the receivers are what 10 quid.
    Possibly good for Irish people mind you with their terrestrial HD trial which is currently free to air from what I've read otherwise what's the point.
    The Arion looks the best value for money and built quality I believe, then possibly the Fortec Passion.
  21. bob1
    bob1
    Nov 7, 2002
    4,472
    Sheffield
    +133
    I had the old combo from technomate and it was very poor ,i didn't keep it long.
  22. wellop
    wellop
    If that's the TM-4100 Combo (if my memory serves me correctly), this is in a different league as it's HD and upscaled Freeview.
    Remlap, I have to disagree.
    The TM-6900 Combo is a lot more value for money as you can patch it, has a Smart Card Reader and has the brilliant USB PVR. None of those HD receivers have these features.
    So think about it. You have to buy a Cam and a Programmer which will cost about £100, so you're better off getting the Technomate HD, and it has USB PVR too!
    And you support a British company! :thumbsup:
  23. bob1
    bob1
    Nov 7, 2002
    4,472
    Sheffield
    +133
    It was a 4200 is was still poor though.
  24. remlap
    remlap
    Apr 8, 2006
    791
    28
    +65
    And I have to disagree with you.
    I have everything you mentioned there in other equipment, why would I want a PVR for multi satellite hardly anyone provides a full EPG except the Germans.
    Support a barely British company, all their receivers are produced in China.
    Arion is a piece of class, this thing is just botched together get it out as quick as possible, waste of money.
    To me you just sound like a fanboy who wants to get free tv.
  25. thfccambs
    thfccambs
    Jul 17, 2002
    23,968
    White Hart Lane
    +6,898
    Fair play for supporting a British company.
    Though everything the TM does so does the Clarke CT 5000 HD and as most people like to save money, Clarke a lot better value box.:thumbsup:
  26. rd100
    rd100
    May 26, 2006
    237
    +13
    I myself would not buy the Technomate it is well over price my mate has one and the pace 810xe has much better HD pic qulity than the technomate i have the Arion myself and it is a good receiver and much beeter than the fortec star HD receiver that i also have,
  27. kwan.b
    kwan.b
    Mar 26, 2006
    13
    Please, would someone confirm that the hacks used for the TM 1000/1500 would be compatable with this machine, as I already own a 1000 (great machine) but want to upgrade to HD.
    :confused:
  28. thfccambs
    thfccambs
    Jul 17, 2002
    23,968
    White Hart Lane
    +6,898
    Your be fine mate.:thumbsup:
  29. tedpon
    tedpon
    Sep 8, 2006
    112
    ireland
    hi wellop,....are you saying that tm hd dosent need a pc hooked up to have it work as a pvr,...so can i use any or all stand alone usb hdd`s,..it seems theres a lot of hdd units that need power,...you say the freecom dosent,...is it powered thru usb? also whats the quality of the bbc hdor premier movies like on playback [presume hdmi] ? :lease::clap::smashin::eek:tedpon,.
  30. tedpon
    tedpon
    Sep 8, 2006
    112
    ireland
    hi orbitalsat,..just one question,...if you have tm hd patched,...where did you get it ,..i cant find it on dm alsat,..one more ? is the patch au as in diablo stealth??? i have just seen mention of tm 1000/1500 patch,how can this be??? cheers,:clap::Dtedpon.
