New system specs
Discussion in 'AV Receivers & Amplifiers' started by moid, May 9, 2003.
  1. moid
    moid
    May 9, 2003
    33
    Leeds - UK
    Hi Im new here.
    I am pricing up some systems at the moment and came accross these two bargins (i think).
    Would the following two items make a good system together?
    TEAC 550
    Limit HC602
    Saving at richer sounds is £750 on a system costing £700 in total (thats over 50% discount)
    Too good to miss?
  2. wilber
    wilber
    Sep 29, 2002
    1,970
    +30
    Don't pay any attention to Richer's savings.
    Neither item would be on my shopping list -
    I'm guessing you want shiny little speakers so kef eggs would be far better - sevenoaks have dropped the price of these to £600 (and 7oaks will usually give a bit if you haggle) & amp wise well any £250 amp from Denon, Marantz, Pioneer, Yamaha or Sony would probably outperform the Teac. You'll find the eggs on this page.
    http://www.sevenoakshifi.co.uk/products/contents/contentsavloudspeakers.html#sub satellite packages
  3. sounddog
    sounddog
    Dec 11, 2002
    3,373
    107
    Leicestershire, UK
    +461
    The Teac system is good if you are wanting something smaller than normal though wilber ... but I agree ... mate it with Eggs if you can afford it.
  4. moid
    moid
    May 9, 2003
    33
    Leeds - UK
    to be honest the look of them was only a bonus. If other speakers are better for the price then I would prefer them.
    What would you suggest for approx £700 that includes all that the other setup had (amp, DVD player, receiver + full speaker package)
  5. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,078
    notts.
    +63
    Hi Moid
    Have a look at the yamaha htr5550 receiver £259 from richer sounds also toshiba silver sd520 multiregion dvd player £200 from richer sounds and if you could stretch your budget a little and get the mission cinema70 pack in silver (5 speakers and active sub)£333 from qed.com you would have a far better system than the one above and i know it would be a great first home cinema system.
    Hope this helps.
    Gonzo.:smashin:
  6. phenom2003
    phenom2003
    Yamaha 5640RDS for £218.96 plus p+p from www.unbeatable.co.uk also has DTS NEO6
    Yamaha HTR5550RDS £248.92 from empiredirect
    edit: the 5640 has alot of inputs removed, notobaly 2 optical ins. Go for the 5550.
