New Subwoofer required.
Discussion in 'Subwoofers' started by yoda, Feb 17, 2014.
  1. yoda
    yoda
    Dec 26, 2010
    14
    Hi chaps, my onkyo subwoofer connected to my Onkto TX-NR509 Amp has died today and in search for a new subwoofer. I have a budget of £150. Can anyone recommend whats good out there to buy for that budget of cash. I am a little confused. So far I have been looking at:
    Wharfedale SW150
    Tannoy SFX Sub
    Tannoy HS101
  2. illy406
    illy406
    Aug 28, 2010
    224
    Wigan, Lancashire
    +10
    have a look at BK electronics subwoofers. they are very highly recommended on here.
    when i buy another subwoofer again it would definately be a BK. i own a SW150 and use it on my home cinema and its great but im just saving for a new sub for my hifi which will be a BK XLS200DF. then i will more than likely change the SW150 for a BK also.
    B.K. Gemini 2 Subwoofer in Black Ash Veneer NEW + Warranty | eBay
  3. yoda
    yoda
    Dec 26, 2010
    14
    Nice sub, but I don't think I can really afford to spend that much Im afraid at this moment of time.
  4. illy406
    illy406
    Aug 28, 2010
    224
    Wigan, Lancashire
    +10
    i,d try and stretch to the wharfedale out those 3 then. the SW150 is £170 new from only the one supplier which is superfi. i love mine its really great.
  5. Big lou
    Big lou
    Nov 2, 2007
    35
    11
    Kent
    I have Had a Rel q200e for many years with my set up, still in my opinion for the size a great little sub
    £500 was a lot of money then, you can see them go for around £160 if in good condition.
  6. jamkart1
    jamkart1
    Jan 1, 2011
    16
    4
    I made the mistake in the past of buying a lower priced Sub, and I subsequently regretted the decision. When my cheap and nasty sub finally failed I purchased a BK Gemini as suggested in the earlier reply, and it was well worth the extra expense. If you say a BK Gemini is outside your budget I would suggest holding back on your purchase and save until you can afford the cost of the BK Gemini. Learn from my past mistake!
  7. mojogoes
    mojogoes
    Remembered (1961-2016)
    Oct 12, 2007
    10,469
    Faraneverland
    +1,984
    If that's it as far as your budget is concerned! then I would go with the wharfedale SW150
  8. nenito2k
    nenito2k
    Aug 13, 2008
    1,385
    +119
    @yoda...i have been saying for many years here that the "human race" sucks ! why ?
    simply because i can't understand why people like to buy "CRAP" ! Why on earth would you buy a rubbish sub ? AS for 20-30£ more (used condition) you can get a GEMINI that will crush any sub 300£ product ?
    You guys are incredible...but hey everyone does what they want with their money...
