New STRD DB 790 or used STR DB940
Discussion in 'AV Receivers & Amplifiers' started by udmrts, Nov 30, 2004.
  1. udmrts
    udmrts
    Hi everyone. First post here. :)
    I have a Sony STR DE485 receiver and want to replace it. I can buy a 790 for 370 Euros. A friend of mine offers his 3 years old 940 for a little bir less than that. Between 250-300 Euros maybe.
    Not all receivers are available here in turkey, and the ones that available are usually more expensive. Marantz 4400 for example, 600 Euros.
    What do you recommend?
    I also have qouestions about speakers and Wharfedale subs, in related areas. please check. Recommendations most welcomed. :lease:
    Thanks.
  2. recruit
    recruit
    If you're not bothered about haveing some of the newer formats like PLII/DD EX/or DTS ES then the sony 940 is a very good 5.1 amp but if you require them then the newer model will probably be the one to go for..
    John
