new stereo bookshelf type sound system required
Discussion in 'Hi-Fi Stereo Systems & Separates' started by eggmanpete, Dec 27, 2006.
  1. eggmanpete
    eggmanpete
    Dec 27, 2006
    26
    I will be leaving for university soon and id like some new stereo bookshelf type speakers to hook up to my pc/cd player to play mp3's/cd's/flac
    unsure of my budget, id say up to £250 (500$)
    Im not looking for PC speakers because ive been told that there are not many decent ones out there. Could anyone recommend me a custom set-up.
    I am currently using logitech Z5500 digital 5.1 pc speakers but i will be losing them when i go to university
    Could someone suggest what to get in terms of amp/speakers etc...
    some of my sources at the moment are:
    pioneer pd 4700 cd player (phono)
    JVC DVD player(optical/phono)
    soundblaster audigy 2 ZS (3.5mm) (may scrap this)
    *update* i'm liking the looks of the wharfedale diamond 9.1 speakers at £130
  2. oShy
    oShy
    Nov 10, 2006
    37
    The Wharfedales are nice. You are going to need an amp to hook up to all your sources though. You can get some very nice second hand amps for less than £100 though.
  3. eggmanpete
    eggmanpete
    Dec 27, 2006
    26
    what about the sound card? i will be playing the majority of my music through the pc rather than CD's.
  4. oShy
    oShy
    Nov 10, 2006
    37
    If you want to replace the soundcard, many peoply recomend the m-audio 2496* for listening to music. You still need an amp to power your speakers though, unless you get some active speakers.
    *might not be right number
  5. eggmanpete
    eggmanpete
    Dec 27, 2006
    26
    thanks, is there anything i can do software wise? like use a different decoder/media player/equaliser? which are the best out there?
  6. deaf cat
    deaf cat
    Feb 9, 2005
    1,224
    48
    +58
  7. eggmanpete
    eggmanpete
    Dec 27, 2006
    26
    which amp would you recommend for the wharfedale 9.1?
    2nd hand or new
    amp should not be more than £100
    cheers
