New speakers - which ones to get!
Discussion in 'Home Cinema Speakers' started by GodtheDJ, Oct 24, 2003.
  1. GodtheDJ
    GodtheDJ
    Am going to buy an MJ pro50 soon, after much consideration and reasearch. I would like to get a new set of stereo speakers and a centre to give my system a bit of a kick up the backside as well. My current setup is:
    -Mission 700 fronts
    -Crappy old Sony speaker centre
    -Eltax LR Bipolar rears
    -Sony STRDE-485 receiver
    I was considering the follow speakers:
    -Wharfedale diamond 8.2 + diamond 8 centre (£200)
    -Monitor Audio Bronze 2 + Bronze centre (£296)
    Would it be worth holding on a while to get the monitor speakers? I have read all the reviews of them and they seem to be my weapon of choice at the moment, though it would be £100 over my £500 budget including the sub. Are they worth the extra wait?
    I realise the amp would be a bit of a weak link in this setup and was thinking of a Marantz SR5300 or Yamaha in the not too distant future.
    Cheers :)
  2. overfloe
    overfloe
    Apr 23, 2003
    230
    16
    Newcastle
    i'd pick the monitor audio b2 anyday.. im using it and lovin' it.. have a demo you might like it too.. and yes, they are worth the extra wait!
