New sound bar for old TV
Discussion in 'Soundbars, Soundplates & Soundbases' started by avramel, Dec 16, 2016.
  1. avramel
    avramel
    Dec 16, 2016
    NC
    I have googled around, read the manual a million times and connect figure out how to get my new soundbar to work.
    I have a Samsung LED TV (un60fh6003fxza) and a Yamaha ATS-1060 sound bar. The TV has two HDMI ports (non ARC from what I can tell), component INs currently being used by a Wii and a USB port. I use an antenna as we don't watch much TV.
    The soundbar has an HDMI out (arc) and an hdmi in. It also has a optical digital port and an analog port. My TV doesn't have an optical port.
    I have a BD player and a chromecast in use with the only two HDMI ports.
    I successfully got it to work with the BD player but no TV or Wii.
    Is there a way to get this to work? If not, can you recommend a soundbar that would work or perhaps an accessory?
    thanks!
    Avramel
  2. JayCee
    JayCee
    Jan 20, 2004
    23,629
    Lanarkshire
    +2,550
    According to the specs on the US Samsung site your Tv has no audio out facilities at all so I'm afraid you're stuck with your present setup of the BD player direct to your Soundbar and with no means of outputting audio from the Tv that rules out all soundbars and amps/receivers.
