New Sony widescreen CRT with DVI
Discussion in 'Desktop & Laptop Computers Forum' started by bonslo, Jan 10, 2003.
  1. bonslo
    bonslo
    Check this out:
    http://news.sel.sony.com/pressrelease/3065
    New Sony widescreen CRT's with Hi-Res display and DVI input
    Should give great results with a HCPC but will they (or similar) be available in the UK while we lack HDTV?
    KV-34XBR910 and KV-30XBR910
    Brett
  2. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    DVI probably isn't a good idea for CRTs since you would loss its ability to do proper customs resolutions and refresh rates as well as limiting it to 8bit colour.
  3. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,257
    Manchester
    +753
    Are you sure about the 8-bit colour ?
    I thought it was 8+8+8 (RGB) = 24-bit ?
    Must check my own (work) website (Analog Devices) + Silicon Image's.
    Chris Muriel, Manchester.
  4. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    Yes but if you use analogue you could have 10+10+10 = 30bit
  5. cybersoga
    cybersoga
    Apr 7, 2002
    1,630
    48
    UK
    +25
    DVI doesn't nessesarily mean digital, it can be DVI-D or DVI-A, or both. DVI-A (anologue) is the same RGBHV signal but using the DVI connector. Sounds like a nice TV tho :)
