new sony s and v series kdls32a12 and kdlv32a12
Discussion in 'Sony TVs Forum' started by stealingthunder, Aug 21, 2005.
  1. stealingthunder
    stealingthunder
    About to buy new sony lcd but can't decide if it's worth the £300 extra to go up from the 's' to 'v' series, ie from kdls32a12u to kdlv32a12u.
    How great is the difference? tks for any help :lease:
  2. neilmcl
    neilmcl
    Oct 29, 2004
    6,236
    103
    Nottingham
    +292
    From what I've seen in past models from Sony the Wega engine in the new V series certainly makes a big difference particularly with standard definition broadcasts and DVDs. IMHO much better processing technology than the Philips Pixel Plus 2.
  3. Kit2005
    Kit2005
    Is the WEGA gubbins applied to SD DVDs that have been upscaled to 720p or what have you?
    TIA
  4. David Mackenzie
    David Mackenzie
    Aug 28, 2003
    10,351
    Glasgow, UK
    +1,312
    No, I don't think so. That transfers the bulk of the scaling duties over to the player.
  5. Kit2005
    Kit2005
    Right-o. How about lower resolutions?
    I recall hearing everrything above 480i bypassed WEGA, or at least part of the feature set, which seems a bit unfair on PAL users.
  6. Ramspeed
    Ramspeed
    Apr 27, 2005
    532
    28
    +24
    It's just that certain picture processing elements of the WEGA engine are disabled when viewing progressive or HD. It's not a PAL or NTSC thing. Wega will enhance standard broadcast. It wall also enhance progressive and HD (i.e. better contrast, colour, scaling etc.). Don't worry. Wega does slightly different jobs on different source material. It's the results that count. And reports are pretty exciting so far...
  7. daxie
    daxie
    Jul 9, 2005
    242
    16
    only they are sooo fricking expensive and sooo lacking in connections...
    anybody has a full spec somewhere on a pdf?
    thnx!
    the only ones being superior than current panels are the v series imo. but when you consider the extra price tag you have to pay for it...
  8. stealingthunder
    stealingthunder
    That might seem a dumb question but I don't know the answer - the s series says it has wxga panels but whether that's an equivalent or lesser form of wega or something else altogether is beyond me. I am not a techie, just want a good picture. The question is still whether the v series if worth an extra £300... :lease:
  9. psotfx
    psotfx
    Oct 17, 2004
    64
    WXGA is a VESA resolution "standard". WEGA Engine is the name Sony gives its proprietary image processing system.
  10. David Mackenzie
    David Mackenzie
    Aug 28, 2003
    10,351
    Glasgow, UK
    +1,312
    I think they are referring to DRC "Digital Reality Creation", one part of the WEGA feature set. If you hear everything about 480i bypassed it, that'll just be from an American perspective. Standard NTSC and PAL signals both get the DRC treatment.
    I think on EDTV (Progressive) and HDTV video, the WEGA stuff is still used to do high quality scaling.
