new solar power tv remote for 2021 samsung tvs
casinoman
samsung is making all samsung tv remotes for 2021 models solar powered. cant replace batteries anymore. will get charged by sunlight or light in house, or by a usb charging cable. last 7 yrs and must get new remote. is uses blue tooth and must pair the remote with the tv. this sucks . all 2021 models what do you think
TROYBOY
thought the solar charging was on of the best things on their new tvs....
PondLife65
I have one and have still to use it, because it simply doesn't have many of the keys that are on the standard remote that I use regularly. Nice idea but unconvinced by the implementation so far.
GapzHn
I need help as mine stays in 65% and does not charge with light. Maybe I am doing something wrong
cuke2u
It's a great idea for the environment. There is a usb-c port on the bottom if you require to charge the remote faster..
GapzHn
It charged up to 100% in 20 minutes with the USB C charger…maybe I had to put the remote control slightly direct to sunlight exposure somehow for the solar panel to work. I dunno
linkinworm
it makes sense for new remotes that have voice control, i think my current remote lasts about a month if i set bixby to always listen and try use the feature, and using cheap batteries kills the remote in less than a few days so id have to buy expensive ones or turn voice off
