New software for HT300Plus
Discussion in 'Projectors, Screens & Video Processors' started by Timclem, Jun 6, 2004.
  1. Timclem
    Timclem
    Feb 8, 2004
    Carlisle
    Recently downloaded this from a link on the AVS Forum.
    New software for HT300Plus and HT300Xtra (non HDMI version) 2.36 (00) F
    Before I install it on my HT300Plus could anyone tell me whats new and if its worth doing. Currently running version 2.21.05
  2. RTFM
    RTFM
    Mar 6, 2003
    1,014
    38
    Horsham, West Sussex
    +17
    Changes in 2.36.00 are:
    New anti-copy pulses management
    Compatibility with 1080i Europe standard
    Jeff
  3. thedoc
    thedoc
    Aug 22, 2003
    262
    16
    Has there been a similar release for domino 30 owners ? I do sometimes get issues with the sync (at projector power up) due to macrovision pulses sent by my Denon Player -- easily cured by switching to another input then back, or using the auto button - but would be nice to apply a "proper" fix if available ?
  4. RTFM
    RTFM
    Mar 6, 2003
    1,014
    38
    +17
    Have a word with your dealer in the first instance and see if he can resolve your issue.
    If he can't then ask him to contact Sim2 UK.
  5. thedoc
    thedoc
    Aug 22, 2003
    262
    16
    Dealer and Eddie @ SIM2 came up with the same fix, using auto to "re-sync" - this must be 4-5 months ago I think. I'll ask them again sometime about updates. AFAIK the 300 software can be used on the domino 30's, but IIRC not all functions fully work - I might ask them if this new software would confer me an advantage with the dreaded macrovision pulses!
    Don't get me wrong though, the issue only occurs perhaps once in every ten power-ups - but it doesn't make you look swish when you power everything up in one keypress on the pronto, and your DVD source is "vertically rolling"! (with your friends round)
