new sky installation
Discussion in 'Sky Digital TV Forum' started by kev3, May 14, 2004.
  1. kev3
    kev3
    Mar 3, 2003
    76
    I getting sky installed at my new house, i've told i'll be given what ever box they have in the van. Unless I know which box i want and insist on it...
    So whats the best digibox to get? best for quick response & rgb output??
    Are any lists & reviews of the boxes available?
    thanks
  2. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    23,390
    2
    In a secret location with Jennifer Lawrence
    +10,337
    Is this Sky or Sky+?
  3. kev3
    kev3
    Mar 3, 2003
    76
    just bog standard sky for now..
  4. Fernsehman
    Fernsehman
    Pace DS430N or its predecessor the BSKYB2600.
    Fast, neat and good service backup if it fails out of warranty.
    Panasonic TU-DSB50.
    Amstrad seem to work OK but reports of power supply capacitor failure are appearing. I think that only independents can repair these out of warranty.
  5. dsk19s
    dsk19s
    its really down to luck dependant upon what the eng has in the depot when goes in --in the morning the panasonic ones though do have a good shelf life .
