New SKY+ Eye not working
Discussion in 'Sky Digital TV Forum' started by Stevvie, Oct 21, 2004.
  1. Stevvie
    Stevvie
    Oct 8, 2004
    32
    I've finally got my Sky+ installed and working after 4 days of no sky due to a bad install. My problem is my tv link or magic eye is not working with Sky+. This is an official Sky one purchased with the digibox. I have turned on the Power in the hiden installers menu(401). The Eye works fine if moved to another room run through the old digibox, so I know the eye is OK. This is an Amstrad box that seems to have poor picture quality compared to my old grundig box. So I will be getting in touch with Sky anyway to change this box for a Pace one. Has anybody got an ORIGIONAL magic eye from a digibox to work with SKY+ ?.
  2. robbie27
    robbie27
    hi
    yes i had sky+ installed and had an original magic eye,the eye worked but i had to buy a new sky+ remote for upstairs as the old sky remote did not work the sky+ box downstairs
