New SKY BB Router
Discussion in 'Sky Broadband' started by nikonuser11, Aug 30, 2013.
  1. nikonuser11
    nikonuser11
    Jan 20, 2008
    5,360
    +874
    Just got the new SKY BB router, larger white box over the smaller flimsy dark grey one.
    My question is I'm not going to use it and SKY said just to keep it, can I use it for anything or can it be used by others if I pass it on?
  2. nikonuser11
    nikonuser11
    Jan 20, 2008
    5,360
    +874
    Anyone?
  3. Stevenage Neil
    Stevenage Neil
    Jul 14, 2008
    9,826
    +897
    Although you can discover the username/password you cannot change it in the Sky router, so your are stuck with keeping it as a spare or using it as a door stop.......
  4. blacksheep99
    blacksheep99
    Feb 26, 2009
    1,240
    +398
    My router is an old sky one. How can I get them to send me a new one without forking out to them?
    Cheers,
    Guy
  5. Hedgehog1979
    Hedgehog1979
    Feb 28, 2009
    351
    Livingston
    +52
    Pretty sure they will send a free one if you re-contract for another 12 months, think you still have to pay the postage which I think is about £2.50 though.
  6. beerhunter
    beerhunter
    Nov 9, 2005
    6,335
    Hampshire
    +740
    Yes, you can cripple it and use it as a Wireless Access Point or an Ethernet Switch or both.
  7. digitaldonut82
    digitaldonut82
    Jun 28, 2013
    129
    Downpatrick
    +19
    I've also got one of the new sky hubs that was used for my fibre connection at my old address, moved back to the folks house to save for a mortgage and they already have sky broadband.
    Can the new hub be used to replace the old grey one?
    P.s sorry for hijacking your post:beer::)
  8. Stevenage Neil
    Stevenage Neil
    Jul 14, 2008
    9,826
    +897
    Without extracting the User Name and Password from the existing router,and inputting those into your router, no. The existing router contains the credentials for logging into the Sky network.
    Why would you want to do it?
  9. digitaldonut82
    digitaldonut82
    Jun 28, 2013
    129
    Downpatrick
    +19
    Does the new hub not provide better signal?
  10. SNIPIT
    SNIPIT
    Apr 8, 2012
    838
    46
    Y Drenewydd
    +160
    In the lab yes, in the field its debatable.
    thinkbroadband :: Sky SR101 ADSL and Fibre Broadband Router Review
    Also as long as they both SKY supplied routers with sky firmware they should be just plug in and connect, no need to worry about user name and passwords.
