New SHARP LC-26GA6E (and others) info/specs
Discussion in 'LCD & LED LCD TVs' started by gmehje, Apr 20, 2005.
  1. gmehje
    Mar 31, 2005
    Been digging around for some info on the new Sharp range - due Sept apparently. Not sure if this is posted already.
    If you are interesed take a look at this link with the specs for the 26" version:
    Text on pdf reads:
    26" Black TFT 16 x 9 WXGA (1366 x 768) LCD Panel
    o HD Ready Compliant
    o Advanced Super View (ASV)
    o High Brightness 450cd/m2
    o High Contrast 800:1
    o Wide Viewing Angle: H:170°, V:170°
    o FM Radio (RDS)
    o Quick Shoot Technology for Smooth Video Image Playback
    o NICAM/A2 Stereo
    o Dolby Virtual Surround Sound
    o Built-in TELETEXT Circuit (TOP/FLOF)
    o OPC (Optical Picture Control)
    o Picture & Text Function
    o 60,000 hours Long Life Backlight
    o HDMI Input (HDCP Compliant)
    S p e c i f i c a t i o n s
    LCD Panel 26" Wide (1366 x 768), Advanced Super View & Black TFT LCD
    Brightness 450cd/m2
    Backlight Life 60,000 hours (at save 1 mode)
    Viewing Angle H:170°, V:170°
    Audio Output 10W + 10W
    Stereo System NICAM/A2
    Terminals SCART x 2, Component In, HDMI, AV/S-Video In, AV Out, PC In,
    Power Source AC 220V–240V, 50Hz
    Power Consumption 110W
    Dimensions (W x H x D) 663 x 556 x 278mm (with stand)
    663 x 504 x 108mm (without stand)
    Weight 15kg (Display with stand), 12kg (Display only)
    Plus this link has the 'full' range 'to be released' range:
    They seem to be a UK company so I presume they are UK specs.
