Quantcast
New setup needed
BCooke00
For the last couple of years I've been using a stingray x with a kayfun 3.1. Both have taken lots of abuse and I'm starting to notice a drop in flavour and vaper even after adding new batteries and giving a good clean. Not looked into new gear in a while so finding it about overwhelming with all the new box mods temp control etc..
So what do you guys recommend?
GMC79
how often do you rewick it? when it's rebuilt it should be back fresh as new. Are you looking for something similar? ie mouth to lung vape? Yeah is lots of stuff about now.
BCooke00
Wick every 3-4 days if using the same flavour, wick and coil every other day if using a dark liquid. May just be my imagination from using the same setup for so long.
Primarily mtl, usually vape at 0.8. Doesn't have to be overly discreet as I'll probably pick up another stingray and run in 18350.
BCooke00
So my early Xmas present turns up this morning, the smok alien kit courtesy of the gf. Chucked the batteries in and had some puffs. Started off at 10w and increased to 22 which is the same as my mech. I then got brave and bumped it up to 40w, that's when the room started to spin. Don't think I've had a hit like that since I put an iclear16 on my mvp2.
GMC79
nice well remember to drop the nicotine level as use more juice. My TFV8 can go thru about whole 6ml tank in around 100 hits at 120w.
Early in my sub ohm days i put in 18mg juice i had without really knowing yet and had rapid heart beats and the shakes within half an hour, can't be good! :laugh:
BCooke00
Giving this a bump as ive just broke my alien, buttons felt loose for a while and has just fallen off.
So looking for a replacement say around £50. I rarely go over 80w and dont use temp control.
BCooke00
Ended up buying another alien kit for £39.99. Did have a look at the GBox so will probably get 1 at the end of the month.
Ivor_Biggern
GeekVape GBOX 200W Squonk Kit
I love my GBox squonker, I’ve added a Dead Rabbit RDA to it but the one that comes with it is pretty good, just a little more leaky.
I'm also using a Gbox Squonker, i rotate it with a Drop RDA and a Oumier Wasp Nano, the Drop is a dual coil setup and the Wasp Nano is a single coil which gives great flavour and is great value for money.
Similar threads
