fearce
Seasons greetings!
Some may recall a thread I set up for a TV / Music set up.
I settled on pursuing a stereo amp setup (with ability to add sub later) as my requirement after having testing an active 2.1 setup, all in one and of course a dedicated amp and speaker setup.
At that time amp and speaker combo’s I tested were:
One of my requirements was to stream Spotify premium without the TV.
Fast forward to earlier this month I done a deal with RS on a Denon DRA 800h with a set of 3020is. I bought the DRA800 as thought the quality and sound would match the PMA600 (having already heard this) and the telesales person confirmed the same. Having run it for around 2 weeks, I felt the sound not to be of the same quality of the testing I did earlier in the year with the PMA600 (same cables, inputs etc used).
To settle the debate in my mind, I purchased last week again, the PMA600 and another set of 3020i to parallel setup and test.
My findings are that both sound different with all other things being equal, though I appreciate there would be some difference as they are different models. But all in all, I feel the PMA600 sounds better 'quality' specifically
So I post here not quite knowing what I’m asking for going forward, but would welcome thoughts anyone has and specifically on the below points….
I’d like the 800h to work out for me as it is a good deal comparatively, functionality it does what I need, but having confirmed my fear of the quality not being up to par, it makes a difficult proposition. I clearly have the option to return / exchange it.
look forward to thoughts…..
thanks
Seasons greetings!
- Yamaha RN303 with Dali Spektor 2s and QA3020i
- Denon PMA 600 with Dali Spektor 2s and QA3020i
- Deeper bass
- slightly more immersive sound which feels a higher quality
- at times the DRA800h sounds thin and not as rich as the PMA600.
- Software both on unit and Apps e.g. Heos and Denon AVR remote not great. Few glitches observed.
- FM / DAB radio poor signal, even with a screw in f connector separate earlier I’ve bought.
- L / R balance, a complete shift from channel to another still results in the other playing some sound e.g. a total shift to L would still see R having some sound come out - is this normal?
- Same speaker cables
- Same speak locations
- Tested using same source simultaneously putting one on mute after the other, so no human memory fatigue possible!
- Sources have been Spotify connect / Netflix / Disney +. All via the TV with HDMI input into DRA800 and Optical running into PMA600 (assume using best each has available).
- Are the sound ‘quality’ observations i’m seeing actually a ‘quality point' or just the character of the individual models?
- The DRA800h as some config available in menu e.g. speaker distances etc - are there any suggestions on what could be done to alter sound for it match the PMA600?
- Any thoughts from existing owners of the 800h on the negative observations i’ve listed?
thanks
