new set up?
Discussion in 'Plasma TVs' started by dali1020, Sep 7, 2005.
  1. dali1020
    dali1020
    Jun 26, 2004
    285
    Reading
    +3
    I will be buying a 50" HD panny or pio in the next couple of mths and would like a new dvd and surround system to go with it, anyone recommend some good units! Is it best to match the brands? Also i have a panasonic SA-XR45 av control receiver which has only been used twice "is it anygood" should i keep it and just replace the speakers etc
  2. UKseless1
    UKseless1
    Mar 9, 2005
    837
    28
    +35
    Try asking the question in a different way. If you put an approximate budget against the project you might get a better response.
    If you have a bottomless pit of cash then the recommendations will be very different from those offered to folks on a shoe string budget.
    How long is your shoe string :)
