New set up advice
Discussion in 'Blu-ray & DVD Players & Recorders' started by LondonPaul, Mar 19, 2005.
  1. LondonPaul
    LondonPaul
    Hi All long time reader first time post.
    Need advise on the following.
    Currently have Grundig digi STB, Cyberhome multi region DVD player and LG VCR all going into a Manhattan LCD tv. Now I want to reduce the kit so was thinking of getting the Sony 500 DVDR with built in Freeview. However looking at other threads, it seems that if I want to watch one channel while recording another I cannot do this vis the Sony. Is this correct? Also my apartment block is having the old analogue TV system upgraded to Sat. All the 5 terrestial will be available with the Sky as an option via a separate socket. I will proberbly sign up for sky so does that muddy the waters still? Is the alternative to go for a Panny DVD recorder, keep the STB and add the sky box?
    Any suggestions would be appreciated as this is driving me nuts....
    thanks
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,204
    Argyll
    +2,261
    With any DVD recorder you will only be able to record one channel at a time - although most models will allow you to watch another already recorded programme on that disc or (if applicable) the machine's HDD.
    Take a look at the 'Which DVD Recorder?' link in my signature for guidance on DVD recorders!
  3. LondonPaul
    LondonPaul
    Rasczak
    Thanks will read your link shortly. I am not fussed about recording 2 programmes at the same time but am confused if, by using the Sony box as it is a digital tuner that I cannot watch for instance BBC1 while recording BBC3 (this is the impression I am getting from the other threads.) Also... does this become totaly irrelevant if I am signing up for the normal sky service (not +). Do I then go out and get an decent Panny?
    cheers
    Paul
