New set up advice req'd - can u help?
Discussion in 'Home Cinema Speakers' started by Blackspeech, Dec 30, 2003.
Thread Status:
Not open for further replies.
  1. Blackspeech
    Blackspeech
    Dec 14, 2002
    69
    11
    London
    Just bought a Pioneer VSX-C301 from Richer Sounds, wanted slim line for existing cabinet and scarts (of which it has 4 RGB). 75 WPC
    Returning on Friday 02 Jan for Eltax Spectrum 5.1 (100 @ RS 50 quid off);
    Questions:
    If I wall mount at picture frame level (top of door) will the sound suffer?/ Will the amp, speakers handle it? The room is 12 X 10.
    I will connect the DVD via component as I do now (direct to TV)and change 2ch audio to either optical or digi-coax DVD - AMP/REC. Assume this is ok, no delay between sound and picture.
    DVD - amp by digi-coax.
    Will require good cables etc - anybody know any decent sites that can match RS for price. Need f/w scart x2. 1 digi-coax. Optical x2. Sub lead x1 (how long do they come?)
    Overall will connect following to amp/rec:
    XBOX/ PS2/ VCR/ Pioneer STB/ Tosh SD220 mr (audio only) Possibly CD player.
    Running on: Tosh 32ZD26P
    Also have Mission 701's /CD/ MD into Sherwood Amp (will be in dining room when I move to new house).
    :smashin:
  2. Blackspeech
    Blackspeech
    Dec 14, 2002
    69
    11
    London
    Moderators please close.
Thread Status:
