New Screen. Now need new remote.
Discussion in 'Home Cinema Control & Remote Controls' started by Josh Bear, Mar 13, 2003.
  1. Josh Bear
    Josh Bear
    Mar 5, 2003
    302
    28
    +52
    Dear All,
    having just ordered my first Plasma Tv, I now want a suitable remote to control my DVD player, VCR the screen and my NTL cable box.
    I was going to buy one of the Prontos, but is it right that they don't work with NTL cable boxes?
    If this is so which one should I get for a max of £200. I have been to remote central but am none the wiser.
    Thanks for any help /advice.
    Josh
  2. Kevo
    Kevo
    Aug 23, 2001
    5,397
    Manchester
    +148
    Pronto works with NTL (depends on model), but if you buy the 'redeye' device (£27 ish|) it will defo work.
    Got mine last week :smashin:
    There have been several posts about this recently.
  3. Jason S
    Jason S
    Red Eye is the way to go, best £30 I've spent on the AV kit yet
    and only 1% of the price of my new plasma, arriving tomorrow!!
    Go with a pronto, £100 - £150 depending on where you buy.
