Hi all,
I've been using an old Sanyo plv-z700 (on its second lamp), with a 92" Panoview screen for many years now, in a standard living room with blackout blinds, and have been reasonably happy with this. I've done a bit of rearranging over the last couple of weeks and found a better layout, but with the screen further away (14.5'/4.41m) so looking to move up to a 120" screen. I've been using a £15 foldup £120 screen from Amazon to experiment with different sizes and think 120" would work. A 106" screen would fit better in the space, but feels a little small at the distance.
I've been looking at screens at around £200-250. I know this is on the lower end for many on these forums, but not sure with my limited setup that I would see the benefit from spending a lot more. So far thinking that Elite, Sapphire and Optima (which seems to be the successor to my Panoview screen from what I can see) look ok. Anyone used these and able to recommend?
DS-9120MGA 120" diagonal 16:9 manual pull down screen
Sapphire manual pull down
Elite manual pull down
