New Scart To Scart Cable
Discussion in 'Cables & Switches' started by BuBBa_FaT_aSS, Jan 1, 2005.
  1. BuBBa_FaT_aSS
    BuBBa_FaT_aSS
    Dec 15, 2004
    64
    Bolton
    Hi all
    Been looking through alot of threads on this forum ( great forum btw) about scart cables as I'm looking at buying a good quality scart lead.
    Now I've seen a few and narrowed the list down to these few
    IXOS XHT801
    IXOS XHT611
    QED Sqart P2110 Performance Scart
    I was moving towards the IXOS XHT801 Silver TILL I came across a thread where someone mentioned RGB only scarts
    Ixos XHV601-075
    QED AV41
    Now I'm bit confussed as to what one to get, I'm after image quality as I have Yamaha amp for sound.
    I noticed that Audiovisualonline have a special on atm
    http://www.audiovisualonline.co.uk/dynamic/eshop_products.set/ref/264/ixos-xhv601-075-0.75m-scart-cable-interconnect/display.html
    now the price is very tempting but would just like some info as to what you recommend.
    TV/DVD I have is
    JVC AV32T25 ( bit dark when set on RGB setting)
    Panasonic dvd S-75
    Any help and info would be grateful as I've spent hours going through loads of threads and still cant make my mind up.
    BuBBa
    :lease:
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    search the forum as you can make the JVC brighter from service menu instructions are on here somewhere..... have a search....
  3. BuBBa_FaT_aSS
    BuBBa_FaT_aSS
    Dec 15, 2004
    64
    Bolton
    Cheers for the quick reply
    Yeah sorted the darkness out abit after finding info on the forum yesterday about this issue, used the remote menu just upped the brightness up to full, other setings colour contrast wouldn't change. (bit of a pain having to keep putting brightness up when watching dvd's)
    One of the reasons I'm looking at a high quallity scart was to try and eliminate this problem and create best possible picture. just not sure what one to splash money out on.
    :confused:
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    well dont go mad, using service menu to adjust brightness (need a Calbration DVD eg DVE PAL to do it properly) will correct this more than a scart lead can... £13 for disc and some playing time or £40 on alead for negligable results? as for a scart lead any of the ones listed will be fine... I actually use these: http://www.tvcables.co.uk/cgi-bin/tvcables/PGV7392.html
  5. BuBBa_FaT_aSS
    BuBBa_FaT_aSS
    Dec 15, 2004
    64
    Bolton
    thanx
    Just PM piero for a copy DVE PAL
  6. BernieC
    BernieC
    Guys,
    I was looking at the QED P21 flat scart at £25 but am now intrigued about Profigold as I am buying 3 leads.
    Hornydragon - do you know how they compare is it that you are more than happy with them and have no need to look elsewhere?
    thx,
    Bernie
