New Scaler...
Discussion in 'Projectors, Screens & Video Processors' started by olliemac, Dec 2, 2004.
  1. olliemac
    olliemac
    Has anyone had the circumstance to use the new DVDO iscan HD+ video scaler. I am about to buy it but thought i'd get some opinions first. It will be working alongside my BG808s and is an upgrade from the iscan pro .
    Oh! By the way, has anyone got a copy of the laserdisc video essentials they want to sell, i need to set up the picture (disparity between dvd and ld quite extreme) and this is another reason for the HD+ as i believe it allows you to save seperate settings for each input......speak soon, cheers......
  2. Boris Blank
    Boris Blank
    Aug 7, 2000
    1,698
    Outpost 31
    +161
  3. Thunder
    Thunder
    Feb 26, 2004
    1,763
    41
    +14
    As what you want is a RGBHV output and not a DVI out, I wouldnt bother with the HD+. I would just get a HD and save myself £200.00 :smashin: Because as far as Im aware the only difference between the two is that the HD+ has HDCP encription on the DVI output :thumbsup: I would also look at the Lumagen DVI and the cinemateq picture optimizer plusII as both of these can be equipped with RGBHV BNC output terminals (the cinemateq has them as standard) which is more ideal for a HQ analogue video output :D
  4. Bob Todd
    Bob Todd
    Aug 20, 2000
    3,080
    UK
    +373
    Where is the best place to get an Iscan HD+?
  5. olliemac
    olliemac
    I can get the HD+ for the same price as a HD so what the heck. What is HDCP by the way. From what i have read it is some kind of security protocol for hi-def. Is this the case??
  6. Bob Todd
    Bob Todd
    Aug 20, 2000
    3,080
    UK
    +373
    could u get me one :lease:
  7. Thunder
    Thunder
    Feb 26, 2004
    1,763
    41
    +14
    Your almost spot on HDCP encryption means that the source and display device have to shake hands in order to function with the digital connection :) I to would be interested to know where you can source an Iscan HD+ for £760.00! :confused: :D
  8. olliemac
    olliemac
    I work in the industry, cant reveal my sources, but you can get it fairly cheap from the states as well. Although i suppose vat and duty would bugger that. Thunder!! How does the display device know that what its greeting is correct. Does it only work with DVI displays??
  9. Thunder
    Thunder
    Feb 26, 2004
    1,763
    41
    +14
    You only need to worry about HDCP if your using a digital connection (DVI or HDMI). If your using RGBHV out to your PJ then HDCP dosnt come into play. The only other reason it would be important is if your using a HDCP encrypted DVI/HDMI output from your DVD player to the scaler. Personally if I were connecting my DVD player digitally then I would go for the SDI module straight from the MPEG decoder :thumbsup:In which case HDCP dosnt matter :D
  10. Vince M
    Vince M
    Nov 2, 2004
    473
    19
    Lagoa
    If you go for the DVDO I-SCANHD+It has HDCP compliance on the dvd input/output.
  11. Vince M
    Vince M
    Nov 2, 2004
    473
    19
    Lagoa
    760 Is expensive now,your talking to the wrong people.. :)
  12. Thunder
    Thunder
    Feb 26, 2004
    1,763
    41
    +14
    Thats OK, coz I just got a Lumagen Vision HDP with RGBHV BNCs fitted for £760.00!! :laugh:
  13. Vince M
    Vince M
    Nov 2, 2004
    473
    19
    Lagoa
    You paid that much? :hiya:
