Hello thanks for the info
I want better wifi coverage plus faster Ethernet ports as I am getting poor wifi connection at the moment
Don't think the super hub 2 is that good to be honest
Yep it's on fibre cable in the house just to the green / brown
Wifi coverage might not be improved by a new router and as many other threads will witness it is not a guaranteed cure and the SH2 coverage is ok (some people have had drop outs though).
Check to see if you are overlapping on the Wifi Channels with your neighbour using one of the wireless monitoring progams like Inssider or Wifi Analyzer as that will give you an idea of what's operating there. Additionally you might want to try connecting to the 5GHz service on the SH2 as those channels have less interference at the moment from you neighbours.
It depends on where your router is, mine for example is the corner of my house and so I actually have a couple of WAP much nearer the middle to give better coverage. The SH2 itself would give me 80% coverage of the house. Each WAP point would again give a similar coverage.
The Ethernet ports on the SH2 are gigabit ports anyway so you won't get faster than that anyway on a consumer router.
