New room, dual cylinders, forum day & PB13 Ultra
suniil
Post no.27 Review
Post no.30 Pictures
We left KHC around 2:30PM after AVForum day with a great satisfaction from begining till finish everything was excellent. This is the first time i attended a forum day @ KHC.
I was there just to hear/feel of Box 13 and meet other members. Met most of the members and said hello, which was the main purpose.
Did box ultra 13 was upto my expections? A short answer is No!. I can still consume quite a lot of LFE. Heard lot of power, bass & loudness in that room but not the real effect of LFE, that i'm familar with other family members of SVSs I have/had.
May be because of the simple reasons, including the seating position, the room or too much of expectation (hays mentioned this).
I read each & every post in forums regarding Box and cylinder ultras. Not seen a single negative comment on 13 ultra at normal (or higher) *listening* levels and some of the high lights goes like this
Get the feeling of air pushing out upto 7 to 8 feet
Dust /sand moving in front of the ports
Feeling of a concrete wall hits your chest
Still gets my blood pumping!
Did I change my mind. No! my name is already in the pre-order list and keen to receive the shiny piano black box. Glad to hear Santa may bring a gift!. SVS can't go wrong, i've experienced their customer service couple of times directly and via KHC, which is absolutely top notch!
Ok, back to topic. Walked straight to living room, after returning from KHC & started playing with my fav bass rich scenes. I've had refurbished my living room after moving in recently and never got a chance to calibrate the sub.
Gathered all the tools & cables required, still misplaced the M-audio USB soundcard somewhere. I've to live with onboard sound, but looks alright for the purpose. Here are some raw and refined graphs along with pics of new living room (most of you guys already seen this)
Tripod ready at listening level to measure up
PC wired up
Below the Raw response graph of Sub1 which has 12.3 driver
follows the Raw response graph of Sub2 which has 12.2 driver
And finally the Raw response graph of dual subs. I've gained 7-8db, for running both the subs together and slightly better response curve. Though it is uncalibrated, looks fine to me, i can get away with 3-4 filters.
Dual subs calibrated [first round - 4 filters
Dual subs calibrated [fine tuned - 2 more filters
I've added another 2 filters to bring down the peaks to make the response better
And finally the subs.
Box 13 will take up the space of dual cylinders, i may have to move cylinders to another room or dismantle :) for my future DIY project
your thoughts welcome!
Orchard6
Suniil
Where did you get the stands that the cylinders are on?
Does this make a big difference to the sound?
Thanks.
Nimby
Suniil
Your room must have the lowest absorption factor I have ever seen.
I imagine that dropping a handkerchief on the floor would alter the room's sound quality. ;)
Member 96948
Suniil, I think a lot of people are waiting to hear a 13U without the 'benefit' of the Audyssey Pro EQ and I speak as someone entirely convinced by the far less complex MultEQ in my AVR. As somone with a pretty hard room (although yours raises the bar somewhat) it's an amazing piece of kit.
The differences it made to the scale of the soundstage in the PB13U room was without doubt, but as with all EQ systems where a manual and therefore, 'personal' input is made, you're left wondering if you would make the same choices. Would you choose accurate over fun? Clearly, that's a question that would generate a range of very different answers.
Russell
R
recruit
Superb room suniil :thumbsup: i know i have already commented on you're room in the HC forum but it really is very stylish....the PB13 Ultra will sit perfectly where the 2 * 25-31's sit, adding some soft furnishings will certainly help though with the sound.
grims dale
when i heard the pb 12 plus 2 at kent home cinema centre earlier this year, it sounded great but when i got it home and spent a few hours it sounded so much better i could feel the sound presure as it tried to push the walls apart so all i can say is if you think the subs at av sales sounded good wait till you get the monsters home all those poor neighbours.:devil:
suniil
Marc, nice to meet you on forum day.
I've no doubt in Ported Box 13 performs well. May be i'm just more bass hungry, or not used to listen the soundstage/surrounds that loud. Now i'm thinking of getting 2 of the boxes that one can fire from sound stage and other from back (where the tubes sits now.). I should have kept PB12/2 to run along with new ultra :(
New neighbour has given permission to visit his house this weekend to check the noise level, though he says he can't hear any sound from my home!
suniil
Just a while ago :)
So, it's arrived, where are the pics! :D ;)
Richard!! sorry for all the pestering since aug 07 & thanks for tolerating me all the time:). Absolutely superb service, please pass thank you note to [email protected] for delivering this.
It's here, when other members said it's massive i never expected this size & weight. For those who are expecting to take the delivery of PB13, please make a note, you have enough friends at home to help you out!
milesr3
Two 25-31PC+ and one PB13 Ultra...I'm slightly surprised and a little disappointed that you're not attempting to hook them all up ;)
Andywilliams
R
recruit
ummm that looks good sunill :thumbsup: although i think you are being a bit greedy with 3 subs in one corner :D
sdb123
suniil - will you be using an Auralex Gramma under the box?
Looks good btw. :thumbsup:
suniil
not that greedy :), going to try in couple of other corners as well. good thing is i can easily move around PB13 on a carpet on tiles!
**Not to KHC guys**
Hi SVS: No t-shirt, no hat, no 5% discount (returning customers) in UK - shouldn't you treat all of us in similar way :)?
Podcast: LG C1 OLED + JBL Synthesis SDR-35 First Thoughts, plus TV Show & Disc Reviews & more
Latest News
What's new on Netflix UK for June 2021
  • By Andy Bassett
  • Published
AVForums Podcast: 12th May 2021
  • By Phil Hinton
  • Published
Bluesound unveils new generation of Node and Powernode audio players
  • By Andy Bassett
  • Published
Naim launches Uniti Atom Headphone Edition
  • By Andy Bassett
  • Published
Sennheiser announces flagship IE 900 earphones
  • By Andy Bassett
  • Published
