New remote required
Discussion in 'Home Cinema Control & Remote Controls' started by pudz45, May 8, 2005.
  1. pudz45
    pudz45
    Hi all, Just wanting some advice on what remote to buy to control a plasma, dvd recorder, sky+ (will it be able to control sky plus functions?) and xbox. If poss touch screen but not paramount. My budget is around £100 dont know if thats feasable but any advice would be great :thumbsup:
  2. GreenBars
    GreenBars
    Oct 29, 2004
    631
    Hertfordshire
    +23
    I use a Universal Remote Control Inc. URC-200, which retails for £90, and am happy to recommend it. I used to use a OneForAll Kameleon 6 (£60), which would also do the trick for you. A lot of people on this forum recommend the Harmony H655 (£70) - never used it though, so I won't comment.
  3. gerbilly
    gerbilly
    Mar 20, 2005
    2,193
    Hamilton
    +94
    Go for the Harmony you wont regret it works sky+ easily and will have no probs with your other devices.
  4. H33R
    H33R
    Not sure if this is useful but Costco have the Kameleon for 39.99
