TwincityWild
Hope everyone had a great easter
Been a while since i posted on the Forums and had to re-register as my login seems to have gone
Anyway to my dilema.....
I'm stuck on which way to go whether it's the A37 new/refurb or A55 or A580 2nd hand so any help would be greatly received
I really just need to know whether the A37 is as good as the A55/A580 in low light at high iso (1600/3200)??? The camera is for a trip to Disney world i have coming up and with the parades etc it needs to handle moving objects in low light which the others do fine. Going to be using both the kit lense on a tripod and a prime lense handheld.
I did look at the A57 but the price is a bit much for me unless it drops. My intention is to buy one of the ones i have mentioned and add a couple of lenses by minolta which will probably bring it up to just over the price of the A57 .
One problem i have found is there are hardly any reviews of the A37 ...tons for the A57, A55 etc. Tried DXO, snapshot and DP review and none had any information to use as a comparsion.
Actually seeing as the A37 has the same sensor i'm assuming it produces the same or practically similar shots as an A57 in low light???? please do correct me if im wrong
Anyway thought i would try the experts...erm thats you
so if anyone can help that would be great
