New receiver recommendation for Hotbird
TVC15
My five year old Technomate TM-7560 2VA receiver which is only used for Hotbird reception has finally expired and I'm looking for a similar SD receiver to replace it with.
I need at least one Viaccess card slot and it needs to have an SD PAL composite video output with analogue audio outputs
I'm really a bit out of the loop with the marketplace and would welcome any advice....thanks
logiciel
cerbera8
I wouldn't recommend buying another SD receiver as many of the broadcasters have now adopted DVBS-2 transmissions which can only be received using an HD Receiver. I suggest as your needs are quite basic otherwise the Digiquest 6670HD which is around £100 and works with viaccess cards from the dealer below.
Digiquest 6670HD MultiCrypt
Otherwise an Icecrypt S3100, or Technomate TM5402.
