New receiver needed ?
snowx800
product is a denon 3310 is refurbished Or a used Sony da 4300 ES
More money is the marantz 5007 new
Main features I need is
--7 channel out
-- a mic set up EQ
-- 12 volt trigger
Not worried about power
More about reliability.
PSM1
What speakers will you be using? What is your budget for amp and speakers (if having to buy some)?
snowx800
I'm just replacing the receiver do a few options
Mainly a 12 volt trigger to turn on amps. I have a Sony ES 2400 7 channel out to amps adcom 5503 3 channel 200 watts per.
I have mission 790se speakers main then paradigm cinema 400
dante01
The Denon AVR2313 would probably be the cheapest AV receiver to currently meet you needs and this will cost you about £400.
dante01
It's missing 7 channel out for my amps
The AVR2313 has pre outs.
dante01
Im in the US. that's why I have to go to a 33 series
Does the AVR2313ci model have the pre outs? We get what is basically the ci models here in the UK so it stands to reason that the ci models in the USA will have much the same spec as the models we have jhere in the UK?
Anyway, if in the USA then pricing will be different and the Denon models may not be the bargain they are here?
Yes, the AVR3313 includes pre outs and 2 trigger outputs.
dante01
Another option would be the Yamaha RXV775 or Onkyo's TXNR717. I'd probably suggest the Onkyo TXNR818 over the 717 though.
