New rears
Discussion in 'Home Cinema Speakers' started by dUnKle, Mar 21, 2006.
  1. dUnKle
    dUnKle
    Jan 1, 2001
    15,931
    +2,920
    Have B&W 603s and a CC6 at front
    Rears I am using a pair of wharfdale bipole speakers - I am not convinced they are the best solution
    I am after small (face the size of a DVD case) speakers that will give me a good rear sound stage - not looking at spending a great deal
    Any help ?
  2. Jammyb
    Jammyb
    Feb 5, 2006
    4,029
    Coventry
    +576
    I'm not sure how you hope to get a better soundfield than your bipoles from very small budget speakers?
  3. paulflowe
    paulflowe
    At a budget price for a pair of small speakers that give a wide dispersion of 'quality' sound, you'll probably find zero contenders. Perhaps the closest would be something like the omnipolar omnisat from Mirage (6.5" H x 5.1" W x 6.5" D.) These are good little beasts but you'll need to get them from across the pond so expect £200 or so in capex. Don't know if this place ships to the UK but http://www.vanns.com/shop/servlet/category/type/267 is an option, possibly...
    Paul. :hiya:
  4. dUnKle
    dUnKle
    Jan 1, 2001
    15,931
    +2,920
    Cheers - they look ideal - will make some enqs
