Goldfiinger
Established Member
Hi so I want to ditch my TV and go with a projector set up.
My main siting position is 5.5m away from the screen.
The screen will need to be a pull down screen fixed to the ceiling. In keeping with the room style the screen casing needs to be black.
I have patio doors behind the screen however I'm assuming this is ok?
the projector will be positioned 1m behind my seating position.
My patio doors are 4m wide so imagine i could easily fit a 100 or 120 inch pull down screen.
For now i don't want to go with an electric screen.
Speakers i have a Sonos beam and two One's so would like it to fit with these. If its alexa controlled even better!
I'd like to spend sub £1k on the setup if this will still get me a high def good level set up ?
I'll be hugely grateful if people can advise which screen and projector i should go for.
Many thanks,
Many thanks,
