New projector checklist
B
bergsey
Just ordered my Z2
Been looking through the FAQ's and couldn't find anything so i'll ask the question.
Can anyone recommend a series of checks to do once the projector arrives? If there's any dead pixels etc I want to find them as soon as possible to get a replacement.
My main problem is that I don't have a screen yet as I wanted to try out a couple of different sizes before making a decision.
Any help appreciated.
Peter Parker
I don't know if the pj has any built in colour patterns, but if you can project a pure white image, and then pure red green and blue, you should see if any pixels are dead or stuck.
You can use a PC to do this via a paint program.
Gary.
buns
if you go to www.milori.com you can download a trial version of colorfacts which itself is pretty useless, but it will have a rake of patterns that may be of use
ad
KraGorn
Bear in mind standard manufacturer warranties don't cover a small number of defective pixels .. each manufacturer has its' own rules for what they consider an 'acceptable' defect rate and for which they won't provide a remedy.
B
bergsey
Thanks... pricejapan has a zero dead / stuck pixel policy on the Z2 valid for only 30 days. So i'd like to find any and get a replacement if there are.
Don't know what Sanyo's policy is, but if PJ can offer a replacement then I guess that's Sanyo backing it up.
K
Kramer
Originally posted by buns
but you will still then need to payfor return shipping....
Unless he's opted for their "free return" (an extra 3.3% IIRC).
:smoke:
🎬 The Top 20 Most Anticipated Movies of 2024
Back
